PurpleDog
I got my PDM installed successfully after having cut all of the large connectors off and hard wiring it in. Bike ran fine, all functions and lights, and indicators worked correctly. I took it out for a 10 mile loop to make sure I was good to go.
I get home feeling pretty good about it; decided I'd throw Jakes HID kit in the bike before loading it up for my trip. HID kit went in easy enough, buttoned it all up and turned it on. I let the HID burn in for a few minutes before testing the high beam - no issue. Indicator and all fine.
Turn the key off, then back on a few minutes later and I notice the HID strobing like it wouldn't fire. I tried the key on/off several times before it finally just quit trying to fire. High beam circuit still worked. So I think well maybe if I fire the bike up - as if my voltage may have been down (although I knew I was at full charge) Try to fire the bike up and it won't stay running - it would fire up for sec and cut off like I was hitting the stop button. Strange, bike was just out. Toggle to high beam and notice the indicator no linger works; however, the bike starts up and runs fine until I hit the low beam and the bike shuts off. I am like wtf? So I figure well, maybe the HID kit ballast is jacked up. I take the kit back out and put my old stock bulb back in. Same condition, low beam circuit is dead, high beam indicator no longer works. However, the bike now stays running while on low beam now - just no power to the low beam wire in the bucket.
Checked all fuses on PDM even though it doesn't look like the headlight circuit is fused. The headlight circuit runs through the HCI that I hardwired in.
So, what did the HID burn out; 1) Hand control switch - unlikley (no high beam indicator) 2) HCI ---???
Any others with experience running the HID with PDM kit? Any useful suggestions. BTW, yes my wire plus kit is looking attractive sitting on the shelf. I don't have time to re-wire this bike again before my trip though.
/pd
/pd
