Ignition key or barrel
Hi,
I've just bought a 2007 K-9 and it arrived less key. Can I get a replacement or do I have to change the whole ignition barrel? Will any type of stock Harley barrel fit?
Thanks....:cheers:
BigDogBro1
Made in the USA
Hi,
Thanks....:cheers:
Yes, the keyswitch is a low voltage/current switch for switching +5volt signal to ground into the EHC module.
Call BDPP http://www.bdmperformanceproducts.com/ and see if you can order a few keys using the number on the face of the switch barrel.
RubWhore
Asshole Extraordinaire
When I changed mine I used a harley barrel key switch and matched it to my Harleys as all you need is a SPST to exicite the EHC then I had won less key to worry about.
Dozer1
You oughta be able to simply get a replacement key. I've lost several of mine. Not sure how the 07's are (mine's an 06), but on mine, simply look at the barrel. There's a number on there. It should say something like "BD-010" or something like that. Your key should have the same number. BD only made like 10 different keys for the ignitions on my year bike. Any dealer should carry a replacement or have a spare you could make a copy of.
