thats because your left handed:roll:I don't get it. My clutch is stock and not hard to pull.
Maybe I ride too much.![]()
You're pretty darn smart for figuring this one out.
I installed the newer version ball and ramp....easy pull....and its considerably alot easier to pull,course I didnt add the new clutch packs and if I get on it it slips.....but all in all its alot easier on the left hand
Tennis ball is the answer. Get the cheap ones from Wally World, as they work just as good as the expensive ones. Get up in the morning, place it in your left hand and start your work out. Easy to travel with too. You will be surpirsed after about a month of practice.Oh yea, let us know when you bust the first one!I can't handle the lever pull of the clutch in heavy traffic. Last weekend in all the fayettville traffic did me in.
Without going hydraulic which will give the best reduced lever pull. Bandit or upgrading to a easy pull ramp and plate kit from Big Dog or Baker?
Keith
I am fresh at this. Do you know the part number or contact for a full kit with everything I will need?Get the Bandit clutch, I put in the BDM easy pull kit in and it only lasted about a year, and was slipping in every gear. Couldn't even give more then a quarter throttle, and it would slip. Put the Bandit in about 6 months ago, haven't had one problem since. Shifts in to gear like butter, goes right into neutral at a stop, before I had to give it gas. Plus I think the pull is easyer then the BDM easy pull.![]()
