took my dog for ride, ended up taking my dog for a walk
11bsoldier
HELP!!! I took my 08 ridgeback out for a rideu having previously mad several trips on it earlier in the day with no problems anyways im sitting at a red light and the bike dies, I attemput to restart it and hear a clunk clunk clunk click click click sound, all lights speedo are working but the lights flicker when I try to start it. I just picked it up from a shop today with a new battery installed! Wtf? I ended up pushing this bastard two miles back to my house with many many breaks along the way. Can anyone help me diagnose this problem??
spadesluck
The bike would not die from a bad battery while running right because the charging system should be giving juice to the bike? If battery where bad it would just not start up the next time it was shut off. I may be wrong though.
jm96732
at idle the charging system is not enough. being that they just put the battery in it i would check to make sure that the connections are good and tight. hope this helps
Iman
found my bike was doing the same thing every now and then. Turned out the gas cap was not venting.
BigDogBro1
Made in the USA
MUST HAVE 12.6 to 12.8 VOLTS AT THE BATTERY MINIMUM.
310CCA or better AGM type battery.
Battery connections and lead wire crimps TIGHT?
"clunk clunk clunk click click click sound"
Is the starter seized?
Disconnect the starter solenoid GREEN wire and take a heavy 16ga wire from the + battery terminal and with the bike in neutral touch the starter solenoid connection and see if the starter turns over.
Let us know what you see.
11bsoldier
Will do all these and post afterwards gys for the help it may b a lil laterim gettin married today but ill definitely let y'all know gys again guys
You need to get your priorities straight. I'm a little disappointed in you. Whats more important.......getting married or getting the dog back on the road :D Congrats on the marriage :2thumbs:
Nukeranger
Nukeranger
:confused: She must be one hot girl to place her above your Dog. Congratulations on your marriage :cheers: and my condolences all at once :roll:. Your life will change after marriage.:D
Ray
I agree ...
I agree as well or something in that area lose.. Congrats on the marriage,,:cheers: you take care of that business 1st, tha little lady and all, or you might be sporting a gray mini van next!!!
Check the lose connections after that ,,, that is what it sounds like anyway ,,
Ray :up:
porkchop
my 05 k9 would do the same thing when l hit the starter button. it turned out the compression reales would stick half open .it would then draw to much amps and shut down the starter curiuct. if you push the realses down it will start.
