Checking oil level?
T Mack
SUCKER FREE
On the 06 mastiff do u check oil with bike straight up or on kick stand? :confused:
gooby63
my k9 06 doesnt have a dip stick. how do i check oil. i take cap off and see no oil. should i? also is it 20w 50?
BadBrad
2005 Pitbull
I think Rubwhore said he uses Rotella T 15W40. You may want to do a search on that and see if anyone has a difference of opinion on what oil is best. And Yes! When you take the cap off, you should see oil.
aspen874
Nice clean install on the Wire Plus Dave, if I bring my bike to michigan can i get you to do mine
T Mack
SUCKER FREE
Ok so the 06 Mastiff u check oil level on the kick stand.
Should u screw dip stick all the way down?
Or just set the dip stick in?
There is about a 1/4 inch difference between the 2?!!!
seatmaker
That sounds scary. My 05 Ridge is checked kick stand up and should see oil at the bottom of the neck of the tube. I'm throwing Mobil 1 20/50 in mine tomorrow. Cycle oil of course
Chopper Dave
SIICK!!!
nice shot of the wire plus install:2thumbs:
Thanks man! :cheers:
Thanks bro! yep yep... N8KAM did a great job on the install:2thumbs: we will all make a day of it and get your scoot done! John pretty much took over the install, he's the man!
T...just set the dip stick in on top of the threads to check...I don't screw mine down....I asked the same question before myself :cheers:
