rubbing compound
BD Butch
i have some overspray on my bike ' if i use rubbing compound and my buffer will it harm my clear coat. i've got ghost flames and i'd sure hate to ruin my paint job
jimizee028
TRUE COLORS COLLISION
Rubbing compound or the use of a claybar will work just fine,however there does seem to be a bit of skill and knowledge neccessary to work the buffer properly,definately nothing that can be taught from reading some directions....
Justintime
Use a buffer and Mequires swirl remover. You don't really need the buffer but it makes the job easier. I would say no to the rubbing compound, it is way too course for what you are trying to do. Even polishing compound is probably too much. Try the Meguiers it works great for swirl marks and minor imperfections. If you find that you need something a little more heavy duty use their X2 scratch remover followed by the swirl remover.
stryfox
Try the least aggressive first.
Clay bar. If that doesn't work try some polish.
Next would be compound.
Last would be sand and buff.
Olde Man
I used lacquer thinner after testing to see if it was safe. Worked great without abrasives. The previous owner got some kind over spray all over it.
Glad you got it taken care of, but I think you were on some very thin ice using Lacquer thinner, any scratch or stone chip could've been a disaster.:cheers:
Ray
Clay bar , no compounds better to be safe than sorry, been there before too!
Ray
