front brake doesnt work the brake light
jaeden2003
06 k9 front brake doenst operate the brake light...does it need a switch? if so does anyone know where i could find 1?
lee
could be the switch (probably is), could be the wiring, could be a connector, could be the light itself...
RRRUFF
Check the little creamic magnet item # 7 on the parts breakdown above. May be broken or you may need to adjust out a little. Be very careful they break easily.
Germanbiker
Got the opposite problem:
once the brake light is on it won't turn off. The only way to turn it off is to put a screw driver in between the mangnet and the switch or to mount off the handles and pull the front lever away from the bar :confused:.
Anybody an idea what all this is about???
Cannot find anything about adjustment in the manual :down:.
Jochen
