At what point (hp) will the clutch power be compromised? I had some work done last summer and now the clutch is so stiff my knuckles crack when I pull ti in, this will cause undue wear to some parts and possible carpotunnel to me. I would not say this build is that huge that this would be needed. from what the mechanic told me this was done: 10.5:1 compression,2.02 valves, .600 cam/springs mikuni 48 mm carb ,intake to match all ported and polished,crane hi-4 ignition. The power is good but wouldnt put pinks on the line,it wont fry the tire rolling in 2nd gear, in the past I have put down some good power (jap bikes) and not had the clutch that this has
