Thousand of threads here on this. Your bike is telling you it needs a new batteryHey guys im new on here and basicly have a problem.I own a 2006 k9 and when i turn ignition on turn signals , nuetral lights flash tach tops out and when start button is depressed nothing happens any clues?
Buy a battery tender also and keep it on life supportBrother i sure appreciate it ill get one tommorrow glad i found this site:flag:
Same here bought last year, really spins the engine over better that anything I have used.:2thumbs:Harley AGM batt for softail is a good one.
Your battery should test 12.8 volts minimum. If that's the original 2006 battery then it's definately due for a new one.
volt test shows 12.4 when turn switch on drops to 12.1 starter wont click lights and tach flas 3 slow times then several fast times
http://www.bigdogbiker.com/forums/group-buys/22079-braille-battery-group-buy.html
