wont start turn signals flashing
moemoe166
Hey guys im new on here and basicly have a problem.I own a 2006 k9 and when i turn ignition on turn signals , nuetral lights flash tach tops out and when start button is depressed nothing happens any clues?
Thousand of threads here on this. Your bike is telling you it needs a new battery
Welcome
BigDogBro1
Made in the USA
Your battery should test 12.8 volts minimum. If that's the original 2006 battery then it's definately due for a new one.
sun_bill1974
While we're on the subject, if it is at 12.8 volts and the engine clicks but doesn't turn over, could you still have a bad battery?
BigDogBro1
Made in the USA
It's possible but not likely. I would disconnect the GREEN starter solenoid wire at the solenoid and run a 16 gauge test wire to touch to the battery (+) terminal. BIKE IN NEUTRAL!!! If this method doesn't do any better, then the starter solenoid contacts or mechanism may be bad if the battery tested good.
This way you can bypass the EHC for testing.
moemoe166
volt test shows 12.4 when turn switch on drops to 12.1 starter wont click lights and tach flas 3 slow times then several fast times
BigDogBro1
Made in the USA
Check the wire crimps on all the wires that connect to the battery terminals. If some of these crimps are loose (especially the wires that feed EHC power) things will act weird like a bad EHC.
An EHC flash may help and would also upgrade the speedo reset after start issue. This new flash makes the speedo do a second reset needle swing again after the start button is pressed. It was done because the speedo would go wacky after a start due to low battery voltage during starting. Resets once after turning on the ignition key and again after starting.
