Pinion Shaft ...Whoa !!
Five Five
While re-assembling my 107" motor I ran into a little issue that put the brakes on the project .... so I thought I would post my findings and results in the event any of you should run across this.
Here is my question to S&S cycle (tech support)
Subject: FW: Pinion shaft re-assembly
Hello Dean
I have a tech question regarding my S&S motor .... I am re-assembling my lower end and while putting the gears and keyways on my pinion shaft I noticed a lot of linear movement of the oil pump drive gear along the pinion shaft around .100"... It just doesn't seem right. Attached is a short video of the gear .... spacer ...gear ...am I missing something.
Bill
[ame="http://www.youtube.com/watch?v=LJgN_7fqv88"]http://www.youtube.com/watch?v=LJgN_7fqv88[/ame]
Here is the response from S&S ...
That is exactly how that should work! Generally there will be around .100" of play.
Dean
john sachs
While the play/movement is normal, you need to be sure the oil pump drive gear on the pinion shaft has the chamfer facing the inside of the motor. :up:
John
Five Five
John
John ..... in the video the chamfer is facing outside I did pull the gears and spacer off to put in the woodruff keys.. gear, spacer, gear, nut .... I cant say with 100% certainty the orientation is correct ...... I will pull the cam cover and take a look .... I've put a few miles on the motor ...what kind of damage will it do if the chamfer is facing the outside ??
john sachs
There is a radius machined on the pinion shaft where the drive gear butts up against.If the gear is installed wrong it can set up a stress riser,which will lead to a crack around that part of the pinion shaft......(chamfer needs to face radius).:2thumbs:
John
Five Five
John
John ..... with that said I'm going to open it up just to double check ..... thanks for the learning opportunity...
:2thumbs:
"Five"
KnotSo
Admin
Good to hear you got her back together and we all look fwd to seening the vid and hearing it run:cheers:
John
I realize I am digging up bones here but wanted to put a picture to this as its very useful information. I don't see this mentioned in the service manual anywhere.
Chamfer needs to face inside of motor. The Pinion Shaft has a radius on the inside.
Radius:
Chamfer on gear faces radius on pinion shaft
Wrong Side or facing out.
Every bit of information helps. I'm thinking about doing my engine this winter. It sucks a qt of oil at about 2500 miles.
