Be careful
jaybird
Make sure you pull the dogs front fender (4-1/2" BOLTS) before you pull into the condor motorcycle wheel stop. It'll leAVE A MARK
chacha
Chaff Your EHC!!
Gotta have the right wheel cup for the Condor -- I think they have three sizes. They make one specifically for long fenders. Never had a single problem myself....
snake1962
Yep, Condor has one special for choppers - low fenders and smaller width front tires. Was at a bike show where they were demo'ing them and were using a K9 and it had clearance - no problem with the fender and they were moving the bike on and off it all 3 days of the show.
05chop
Even with the correct chock I had to grind 1/2 inch off both sides then used spacers to center chock.
Little-Boo
I did the same as you did. I have two chocks one on the lift and one on the trailer. The one on the lift is perfect, however the one on the trailer was about 1 inch or so to long. I just took cut about 2 inches off. That worked for me. :2thumbs:
Carlos
