2004hdfxsti
Hello. I just picked up a 2003 Big Dog Chopper, and the clutch is very hard to pull in and takes a lot of effort to shift. It has Ultima 6 speed in it. Any ideas on if these issues are related, or what the issue might be?
It may just need to be adjusted. I'm not a gear head by any means. Just something I would check into.Hello. I just picked up a 2003 Big Dog Chopper, and the clutch is very hard to pull in and takes a lot of effort to shift. It has Ultima 6 speed in it. Any ideas on if these issues are related, or what the issue might be?
Well it came with a Baker tranny so until you pull the primary and check out the clutch and everything you won't be able to get much help here. Could be something as simple as your cluth cable and lever need some lube!Hello. I just picked up a 2003 Big Dog Chopper, and the clutch is very hard to pull in and takes a lot of effort to shift. It has Ultima 6 speed in it. Any ideas on if these issues are related, or what the issue might be?
