RRRUFF
Looking for info here! What's the difference between the 05 & 08 or later S&S 117 engines. I know the valves, springs, rockers, & rocker boxes are different but what else? The reason I am asking is the level of valve train noise. I have two friends with 08's one carbureted the other fuel injected both of these engines have virtually no valve train noise. I have swaped my 05 TP rocker boxes, rockers, to S&S and had the heads reworked with larger valves, heavier springs & brought the compression ratio up. Swaped out my stock cam for and S&S 600 cam. So now I think my 117 is a full S&S. I had hoped that going to the full S&S set up would do two things, 1) quite the top end down and 2) correct the valve to rocker mis-alignment issue. The alignment I believe is corrected but I still have alot of valve train noise. I have adjusted the valves 4 turns and 3 turns and I run Mobile 1 full synthetic with an oil additive. My 05 sounds fine when I first start it up but after the engine gets hot it gets very noisy. I know these engine valve trains can be quited because I hear later models running as quite as a church mouse. So what's the difference in the 05/06's and the 08's and later engines?
