Thumper169
I purchased this Ridgeback with around 60 miles on it or so and I rode it about 6 miles and it was blowing/slinging trans fluid everywhere from the drive side, after replacing the seals,regluing the plug and sealing it all up again its still doing the same damn thing, its like this SOB isnt venting, I took the vent line off and its clear but with it hooked up to the trany you cant blow or suck any air into or out of the trans. Its also leaking on the top drive side tranny cover bolt valley , actually filling this up and running out. Any ideas? The plug on the drive side that is known to leak was and still is screwed all the way into to hole bottomed out on what looks to be another bolt Im starting to think I made a grave mistake here.
