585 change
irishkidjoe
What is the part # for that S&S 585 cam i have a 2005 chopper DT and would like to install this. Also does anyone know how long it would take to install new S&S rocker box kit for my chopper it's got TP'S and it F'in leaks!
Trainguy
Chromeoholic
33-5109 on the part number from S&S on that 585. Nice upgrade just did mine from the stock 546:eek: Their all over e-bay for about 100 bucks:2thumbs:
Splitlog
I have the 585 and love it. It made a very noticable differance. More power and torque from low to high end..Not as noisey as my buddys 600. and Mine is faster and I weigh 80 pounds more than him..
V
Take your time and clean all parts as you go, re-adjust valves, clean all parts as you go drink a beer or two and clean all parts as you go. 3-4 hours taken your time and cleanin al parts as you.
Locktite will not stick to oily or greasy parts. When I disasemble I throw my bolts and nuts in a small pan of cleaning solution to soak while I'm workin.
I went with the Woods .590 W8 cam pulls good.
Trainguy
Chromeoholic
So should he clean the parts or not? :roll:
Steve1028
:roll::roll:yeah, he should clean the refridgerator out of beer and...parts, what parts?
By the way, what kind of hp/tq can you expect with the 585 change?
Trainguy
Chromeoholic
Lot of 600 cam stuff and numbers. Nothing on the 585 other than a lot of :2thumbs: from those that did go that way including me. Bike pulls much better now than with the 546:eek: Some say about 10% with the air and exhaust done first?
Steve1028
Thanks, it's definitely a change I'm looking into...starting to make my Christmas wish list a little early this year!:2thumbs:
Trainguy
Chromeoholic
If you have a 2005 bulldog. Hell you most likely already have a 600 cam w/the good springs and higher comp. The latter dogs they started to EPA.
Just sayin:2thumbs:
seatmaker
05 was the EPA year. I had the 585 and the E carb. I converted to the 600 and G Carb. Definitely a difference in sound and performance compared to a 585 and E.
Just sayin:2thumbs:
05 brought many changes to the BDM line like the 117 motor, E carb, smaller valves and double springs. Plus the TP rocker boxes that were used due to them being quieter. EPA is sound as well as emissions! This along with the RSD, DSSC, DD6 and others.
But the cam was still a .569 or .579.
06 they went back to the G carb after they figured out it still met EPA requirments.
I don't think the .546 cam came out till a couple years ago with they started the EFI (but I could be wrong).
:cheers::cheers:
seatmaker
Damn corrected by Ray again. Even makes more sense now that I had something smaller than a 585. Wonder if Beezer will hire me part time after hours to better educate me. :) Guess I need to stick to seats but I'm about done with that too.
BFB
Bad dog, no bisquit
Is there a thread with pics showing the install of a 585? I did not find one with the search. Not super mechanical but get by with a little help from my friends.
Rally
the 05 also came with the restrictor plate but not sure which was the stock cam for the 05's?
The 585 or similar seems like the way to go if you don't want to spend all that extra $$$ and clean up the heads will help.
DR BULLDOG
DR BULLDOG
I Just Installed The 585 S&S cam in my 107 Great Improvement Power& Sound Changed Jets To 33 & 79 S No poping cranks great also going to install the S&S reed valve in the crank case does anyone have any Dyno numbers on this set up Also running A Santee 2 :up::up:into one Lake Pipe With A Custom Baffle You Stock Dogs Stay on The Porch Ride Safe And Often//Donny:up::up:
myanoch
I finally settled in on move and job at Indianpolis IN.
I changed jets to .32/78 one more step to help with the lean condition after air cleaner install
makes life easier
