scubaman15
This was taken off the S&S site .. I wonder how many used this method :lol:
I did change the oil in the first 50miles ...and was easy on her for the first 250miles ...then I think the first of many smiles were attached to my face
I will tell ya this my bike run's very strong and continues to delight my right hand
and piss off my HD buds !!!
NOTE - S & S Engines require premium gasoline (octane 91 or higher) for best performance. Octane boosting gasoline additives may be necessary with marginal gasoline. CAUTION - Low octane gasoline and hot weather can cause detonation and extensive engine damage. Never try to power through ignition knock ("ping," "rattle," etc.) by opening throttle. CAUTION - If engine is run with foreign material in the oil tank, engine damage will occur. Engine damage caused by foreign material in the oil tank is not covered under the S&S warranty.Clean oil tank and oil cooler and flush or replace oil lines before installing engine in frame. Engine Break-In Procedure Note: S&S engines are designed for high performance and as such are not as tolerant of inadequate break-in as stock or lower performance engines. Correct breakin will assure longer engine life and will prevent unnecessary engine damage. Engine damage caused by improper break-in is not covered under the S&S warranty. A. Initial start up. Run engine approximately one minute at 1250-1750 rpm. DO NOT crack throttle or subject to any loads during this period as head gaskets are susceptible to failure at this time. During this time, check to see that oil pressure is normal, that oil is returning the oil tank, and that no leaks exist. B. Shut off engine and thoroughly check for any leaks or other problems. Let engine cool to the touch. C. After engine has cooled, start up again and allow the motor to build some heat. Engine should be run no longer than three to four minutes. When the cylinders become warm/ hot to the touch (approximately 150) shut the motor down and let it cool to room temp. Follow the same cautions as for the initial start-up, and continue to watch for problems. D. Repeat this procedure 3 or 4 times. Each successive time it should take slightly longer to warm up and you can increase the temp slightly each time (+10). You can be more liberal each time with the rpm, gently vary rpm continuously from idle up to 2500 rpm in the final cycle. Don�t be too concerned with final carb settings at this time because idle speed and mixture cannot be correctly set until the motor reaches full operating temperature. The motor should not reach that temperature during these cycles. Do not allow engine temperature to become excessive. After the motor has cooled to room temperature for the final time you are ready to start the 1000 mile engine break-in process. E. The first 50 miles are most critical for new rings and piston break-in. Engine damage is most likely to occur during this period. Keep heat down by not exceeding 2500 rpm. Avoid lugging the motor, riding in hot weather or in traffic. Vary the engine speed. Do not lug the engine. We recommend changing the oil at 50 miles. F. The next 500 miles should be spent running engine no faster than 3500 rpm or 60 mph. Avoid continuous steady speeds, and do not lug the engine. Vary engine rpm. We recommend changing the oil again at 500 miles. CAUTION - Lugging or running engine prematurely at sustained high rpm may result in damage to pistons and other engine components. S&S voids it's guarantee if engine is not broken in properly. G. For the balance of the first 1000 miles the motor can be run in a normal but conservative manner. You can be more liberal with the rpm range and motorcycle can be operated at normal highway speeds. Avoid overheating or putting any hard strain on the engine: no drag racing, dyno runs, excessive speed, trailer towing or sidecar operation. H. After 1000 miles, verify carburetor jetting and adjustment. Change the engine oil. Motorcycle can now be operated normally. I. Have Fun
