Handlebar Weld Issue
dingo
First 50
Well this could have made for a bad day......
06 K-9 11,500 miles....was just setting out this morning on a 200 mile highway run when, 1/2 mile from my house, this happened:
I don't recall seeing this happen to anyone else....there was no indication of any stress in the chrome before this happened......called the service center and now waiting to see if this might be covered.....will let you know....cheers
Splitlog
There is "RUST" on the edges. It had to be cracked for a while before the rust would show up, unless the pictures were taked several days after it cracked??
dingo
First 50
wow........ glad you didnt get hurt..
Thanks, Eric.
HOLLLLEEEEEY SHIT! Man ur lucky!
That was exactly the first thought that ran through my head.......guess I should go play the lottery now...
Pictures taken today 10 minutes after it happened.
Splitlog
10 minutes.?...there had to be an internal crack where moisture/humidity came from inside for that rust to be forming already..I was a traffic investigator for about 8 years.
there is no way that just happened. It had to start from the inside for several weeks..
your are very lucky...odd it cracked from rear and not from the front where all the pressure would be...It may have been there since it was new. it just took time to weaken. I would contack BDM about it.
dingo
First 50
Absolutely agree that this was a festering problem and, therefore, an accident waiting to happen....
Thankfully and strangely, the part that held is still rather solid.
Waiting to hear back from the service center.
gearsmithy
doesn't look like the weld failed to me, that's about an 1/8" off the joint. maybe they had too much heat in the original weld and caused undercut resulting a stress fracture of the parent metal?
RRRUFF
I have never seen this on this forum or the other I was on. Wow glad this didn't turn out nasty for you.
dingo
First 50
Thanks all....I definitely got the best possible outcome from that situation....
Service Center has submit the claim - waiting to hear....
Dingo.....if BDM doesn't take care of you Splitlog has some bars for sale.
Thanks, Mickee, saw those but I think they were sold.
dingo
First 50
Interesting point, gearsmithy, thanks......I wish I knew more about welding to comment in a meaningful way.
sh8kr
Dingo, contact Chris04mastiff (member here), I gave him a brand new pair and don't now if he used them since they are for the BDM controls.
Steve C
erldawg
That is incredible thing to happen. I've never ever seen anything like that happen. I'm glad you were close to home and everything turned out for the best!!
