Mario77746
Sorry, just got back in town.Are there any other lights still on when the bike dies? Headlight, turn signals, brake lights, etc...
Dennis
Everything electrical shuts off then turns back on.
Dennis
Dennis
It sounds like there's a short somewhere that's tripping the internal EHC breaker. Is there anything in particular you do when the bike shuts down like flipping from low to high beam (or vice versa), or blowing the horn... anything? If there is it may give you a clue as to where to start looking.Everything electrical shuts off then turns back on.
By wiring the ignition module directly to the battery it seems you've ruled out it as the culprit. Something else must have a short that's causing the EHC to nod out.I wired the ignition module directly to the battery and took it for a rip. Within 2 miles the speedo was completely dead. Nothing was working on it but the bike was running down the road just fine at 50mph.
Not necessarily! You need to make sure you don't have a short somewhere BEFORE you waste a shit load of money on another EHC or even rewiring the bike! There's been a number of members here that have replaced their EHC (either with another EHC or an after market solution) thinking it was their problem only to find that they still had to deal with the real problem later...I started to think well positive at least I have it figured out. Negative now either drop $475 on a new brick of shit (EHC) or rewire.
As far as running bad even though you had the ignition wired directly just keep in mind that the coil also gets its power directly from the EHC, not the ignition module.I rode for another 12-15 miles. I could feel something was still not right. There seems to be a very slight hesitation for a split second every now and then. It was running fine then it started to spit and back fire like crazy. I looked at the speedo and it's dead again. I pull in the clutch and the bike dies as I roll up to a stop light. Now the back firing says it's got fuel so there still must be an electrical issue. Also, the tach started to flash on and off then dim to bright but the rpm was reading right.
The EHC can cause all the symptoms you're seeing so you need to find out what's causing it to go into protection mode. I would start looking for shorts in the most likely areas such as chaffed wires around the swing arm, rubbed wires in the headlight housing, or chaffed wires under the gas tank.WTF does that mean? My EHC is shot explaining the problems with the lights and speedo and either the ignition or coil or some sensor for the problem with the motor? What could cause both problems?
It looks like both the Ign Module and Coil are fed power from the same source within the EHC, 13 & 14. I only tapped into the red power wire (14) to the module to give it juice. I'll start by tracing the red wire that powers the coil from the EHC and the Yellow wire that connects the coil to the module. That also may explain why the tach started to flicker before everything went out.As far as running bad even though you had the ignition wired directly just keep in mind that the coil also gets its power directly from the EHC, not the ignition module. Dennis
Yup. Took the switch off and wired it directly. I got a few looks when I pulled into the gas station with wires hanging out of the hole that I had to take apart to kill the motor.Have you checked your ignition key switch to see if it's worn? With it running wiggle the key and see if it shuts down.
Hey Snake the charge was $160.00 for ignition module, and the rest was all labor hours for the t-shooting. They are reputable shop, and fabricator, just not up to speed on the electronics and computer crap. They have "credited" me the labor hours toward continuing t-shooting. What sucked is they thought it was fixed, bike behaved normally for about 70 miles then went right back to shutting off again. Unlike Mario though, mine is only shutting off ignition, all other electronics are still on, lights, horn, speedo etc. Corporate sent a software patch for them to upload to my bike, so..... I have asked that the old ignition module be reinstalled and then test ride, the shop agreed to try that, now I am waiting to hear if they think the software updates were the fix. Fat lot of good my new hexhead 3/8" ratchet drive sockets will do for problems like these.Sorry to hear of the run around. Do not want to beat up on the shop for I am not there, just always wonder why they charged you $468 and that did not fix the problem. To me if you are going to charge for a part, they better be sure that part is bad and was troubleshot, otherwise the shop is guessing and do the old part change until they hit the right combination.
Try disconnecting the coil & ignition wires that are coming from the EHC. Just use the temp. wiring that you installed. Then see what happens. :2thumbs:Both still have the wires connected that lead to the EHC. I have a fuse and a switch on the line that goes directly to the battery. Now here is the interesting part. It shut down again.
