)4 Big Dog Pit Bull wont start
04 Big Dog Pit Bull. wont start
:bang: I just rode it yesterday for the 1st time since winter, The bike run fine. Today it won't start. Just turns over now spark. Thunder Heart light is not paulsating when i turn it over and there is no spark to the plugs. Pulled both connecting wires (1 at a time) to the thunder heart and had power with test light. any suguestions on whats wrong? Thanks (2004 BD Pit Bull)
surferdude
dry docked
Check your battery ... mine did the same sort of thing. Ran like crap but after charging the battery it ran like a mad dog. Hope it's that simple for you too. :D :up:
bad chad
puredestruction, suferdude is right if you have a voltage meter check your battery see what kind of volts is in your battery, than maybe check how much its dropping when pushing starter button.. i had same problem to i learned to keep a battery tender on at all times.... do you keep a battery tender on it??
mobsta
im thinking if dat mother has enough to crank it probably aint the battery.did you check for power at the coil?these dogs do funny things with a low battery but again anytime my battery was weak it wont crank.i also have an 04,im just sayn,what ehc do you have?
mobsta
one other thing to check if you dont have spark or power to your coil is your cam sensor,just somemore things popping in my empty head,good luck and keep us informed:cheers:
bad chad
good point mobsta had buddy had a 04 mastiff men i worked on it for hours.... finally i thought ehc was shot.. so i took it strokers in dallas, they said it was the ehc, cause bright light quit working and they said that was a sighn trowards the ehc going out... so they put a new one on and still wasing running...long story short it was the cam sensor or trigger plate it was cracked... they charged him 1700 dollars all it needed was a 40 cam sensor they said they had like 12 hours of labor trying to figure it out.... but being electrical computer they cant take back off.... but they said before it was deffently the problem... glad it wasnt me paying we would have problems..... but anyways the bike had same symptoms puredestruction no fire but day before it ran fine.. goodluck
Yeah all is good. No spark to plugs, Wires or all good. It's either the ThunderHeart or the cam sensor. I just cant figure it out. Never delt with a cam sensor where and how do i check it? i know dumb question, but i can't find the cam sensor. Any Pictures available?
V
Not sure about your engine but on the 117's the pickup is mounted on the front of the engine right near the plug for the voltage regulator.
On the 107 it may be in the camshaft nose cone, I'm sure some one can chime in on that.
Also as far as charging goes make sure your circuit breaker form the VR is not tripped and you're getting a full charge back to the bat
yeah i have the 107 but what nose cone? Thanks I think i need Pics lol
Sitting on the bike , right side.
is there any easy way to get to the cam sensor i pulled the cover and looks like i have to remove my pipes and pull the whole main cover off as it shows nothing with the round cover removed?? Ok #1 i never dug into an electrical system so treat this as i'm blind lol i need pics and detailed info if posible. thanks going to change my name to MeatHead cause right now i feel dumb lol
pig pen
The coil is mounted behind where your key goes. Be sure all the wires are connected. 2 plug wires and 3 small wires. I've had one of the small wires brake before.
thats what i figured, have to lift my tank to unbolt that cover. What i can see is that they are all connected and in good shape but i'll pull the cover thanks. Any idea where the cam sensor is maybe a pic or something
Battery is new and working fine. Rip's that motor over fast. I just have no spark to plugs and ThunderHeart light does not come on
