Clutch Hub, Basket Problem 03
Five Five
Checkiing the drive train this weekend and I noticed that when I spin the clutch hub the clutch basket was moving up and down and I could see the primary chain going tight and loose in the stationary position....can this unit be rebuilt or is it trashed...:bang::bang:
55, You'll need to pull it down farther to see if it's a broken basket or there is a bad bearing or if the case has been ruined.
Damn, you sure got some bad luck going on. :down:
Sorry!
dead :cheers:
Five Five
Brand new main shaft on the tranny.....
I will pull the clutch unit and do an inspection on it.
something is bent or broken...
thanks Dead / Kool
chacha
Chaff Your EHC!!
Hummmmm...who did the tranny rebuild to put the new shaft in? me thinks a bearing is no more....
Five Five
It's a new tranny less than 300 miles on it.....mainshaft and clutch hub is tru....with less than 0.002" runout.....its the clutch basket that wobbles...
