Spike vs. Dual Runner dyno run
Trainguy
Chromeoholic
I'm no motor guy, and I want to believe because i'm running that combo without the cam (yet) BUT there are some motor guys on here that are runnin bigger cams, head work, decks cut, ignition upgrades etc. and can't pull 120 ft lbs of torque? :eek:
Trainguy
BadBrad
2005 Pitbull
Hope Steve doesn't mind, but the dual runner can be fitted with spikes.
Are you sure about that? Do you have them or do you have pics of this set up? I would like to do that set up as well but have not heard that it can be done with spikes.....until now. :eek:
Husker-Wolf
Check this link out:
D&M Custom Cycle - Metric Adapters - Accessories - S&S Dual Runner Adapter Kits - 2 into 1
They are very expensive, $800 to $1000 for the pair depending on style. I talked to him last year at Sturgis and almost got a set, but they didn't have the ones I wanted with them.
Husker-Wolf
Why do that?
I probably won't, but if you want your bike to look sic then they are cool. You still have the benefit of the "dual runner" intake design, but maybe with a slight bit less air flow. I don't think it would be that big of a perfomance hit for what most of us do with these bikes anyway.
Fast Vinny
Trainguy
Bone stock a 117 makes about 100 ft lbs, get it breathing better and 120 is very attainable. Bking is getting 119 out of his pitbull with slip ons and a dual runner.
Ride on,
Vinny
BadBrad
2005 Pitbull
Its ok. Spikes not from S&S. But you’ll loose the maximum function of what you just purchased. Why do that?
I have to agree with Husker on this. These bikes have a lot of power and torque. I wonder what the difference is between the stock breather and the dual runner with spike filters? Some things just look so damn sick, it's worth giving up a little on hp. :whoop:
MARV
Ride on,
Vinny
i have to cal BS on this.
you aint getting 1 ft/lb per cu in with just pipes and filter on a stock bike.
:down:
Trashman
I would be in for a group buy on the dual runner and cam, already running the V&H 2 into 2. Anyway I can find out if my 2004 Chopper RT with 107 will handle the 600 cam without additional mods?
Magoo
Dog Locked
I too would be in on the cam & dual runner if my 07 chopper w/117ci would handle the 600 cam :2thumbs:
bkingjr
I got 119 ft. lbs of torque with stock cam, BCT baffles and S&S dual runner. Check it out. Here's the link
[ame=http://www.youtube.com/watch?v=VOyKrL-wPyc]YouTube - pitbull dyno run_0001.wmv[/ame]
myanoch
Is there a considerable increase from the stock air cleaner
I have a 117 with V&H bid radius and s&s .585 cam
Hey guys i have a 2009 Coyote 117 with a 600 cam 640springs 10-5-1 comp thunder-jet the boss spikes runs 122hp & 125tork.It only has 500miles on the cam and springs.The bikes is apart now going all the way .Bob wood 650cam ,11-1 comp, port and polish heads, big vaules, roller rocker arms, thunderheart Ing, thunder-jet.
Daisy cutters exhaust with the Boss Spikes.Will have for sale cam, springs kit ,stock vaules, rocker arms, stock Ing.Beagle Man
