speedometer
Yeah, the little sensor at 8:30 on your speedo cover is the sensor just like in your newer vehicles. Make sure it's clear and not filled with wax or polish.
glasspack
thanks ray i thought of that but have not look that close tried a light if you ever find your self in GA look me up
With a name like "Dallas" I'll do that. Thanks :cheers:
By the way if you watch my vid on my Run 21 ride you will see as I ride through the trees that the speedo is changing often due to the sensor.
[ame]http://www.youtube.com/watch?v=-o4beZTQyak[/ame]
bigdogtech01
Yes this is most likely the problem,, take a Q-tip and clean it out, should be good to go.
glasspack
did not get it fixed don't wont bike down for a weak or two or more waiting for a new speedo to come from big dog still riding
That sensor is in the tach ring not the speedo so if the speedo is working correctly then great. You may have to pull it apart and make sure the tach ring is clean and check all the connection. Anyother parts of the tach ring not work?
BikersDream
We build what you Dream!
Yes what he is saying. I keep that part in stock.
