Son of a Bitch!!!front is 3/4" axle
rear is 1"
Boy, I really need to stop drinking!!! :loony:6205 stooge!![]()
+1I have always banged them out with a punch and put the, back in with a snap on bearing tool.
If you have to change out your bearings every 10K something else is probably wrong.I have PM wheels and the bearings for my wheels are crap not to mention hard to find and I have to replace them everry 10000 miles......please.
I took my ride down to my local custom guy and had them mill out the front hubs to accept the new "standard" size bearing that Harley and all the other V Twins have switched to. This bearing is "sealed", twice the thickness of the BD bearing, slightly larger in diameter and I can walk into any Harley or V Twin shop and pick up a set for 10 bucks each .Oh and the best part of all, these bearings only have to be changed out every 60 to 70 thousand miles. Thats right every 60 to 70 thousand miles. They also fit the axle just a little bit better than the BD bearings. All this for the low price of just 300 bucks.
The 05 manual does state to replace every 10,000 miles. It was changed the following year and now states to inspect or replace if necessary or something like that.So I ordered my service manual today. Probably should have done that before I made the statement above,06 K9. Do you know what the service manual says about the wheel bearings. Raywood indicates his manual says replace every ten thousand miles. Is this correct for the 06 K9? If I am wrong then I am wrong but I see alot of threads on here about changing bearings frequently and everyone having trouble finding the right bearings.
WHat do you think of this idea RayI have PM wheels and the bearings for my wheels are crap not to mention hard to find and I have to replace them everry 10000 miles......please.
That's kool but as I posted above if you right in a lot of rain and stuff I would still be replacing or at least inspecting them regularly. May not be an issue in a moderate climate like where you are.WHat do you think of this idea Ray
Thats a good time to do it, there cheap enough to do it at tire changes, just make sure you install the correct way, meaning press them in by the outer surface.Makes me wonder how mine are holding up, I got the bike with 10,000 mi on it, who knows what they look like, but I think I am gonna just change them out anyway since I am about to replace my rear tire!:2thumbs:
Haha no flood. The other side didn't look that bad. I got caught in 1 really good rainstorm for about 20 miles of a Texas downpour about a year ago and thats the only rain for the most part it has ever seen. I was surprised myself how they looked honestly. I usually don't take it out if rain is forecasted.Was your bike in a flood? I changed mine out at 15K and they were still greasy, one was a little rough feeling but the other 2 were smooth and I changed them anyway.
Has anyone found a full sealed direct replacement bearing?Well, since BD used cheap bearings in everything you should replace them with sealed bearings and not worry about repacking them...
