BigB
Started as no low beam sometimes, now no low or high beam. I checked the headlight plug, the plug under the tank, the hi low switch connection, nothing made a difference. All connections were clean and connected didnt find a short. I got up today turned on the key and had low beam, no high beam. Turned the key on and off a few times and no light at all again. I checked the bulb and both beams work with voltage from a bat charger. I was wondering if it could be the EHC or what else should I be looking for?
Thanks
B
Thanks
B
A "hit and run" is when someone uses the site to get information, but doesn't continue to participate in any of the forums. We aren't all mechanically minded, but are committed to helping each other out. There is give and take and a sense of comradery. I think that is what was meant by "hit and run" in this instance.
