S&S Response on Serial Number
I called S&S and this is what they said.
It has the .547 Lift Cam
The "taller cylinders"
The Standard Heads (2.02 and 1.65 Valves)
Roller Rockers
What do you think? Why would it have the larger valves with smaller cam?
I do plan on taking it down, shaving cylinders, install 600 lift cam and 640 Lift Springs.
Do I need to be concerned with Valve Size? I guess I can check when the Heads come off.
Is there anything else suggested while the engine is down? Flow the heads or are they good from factory with 600 lift cam?
Thanks,
Aaron
