TLB08K9
Ray I see where you say this works fro the 05-07 what about 08. My 08 just starting doing some weird things this weekend on a ride. It will not cycle but about every 6-10 times of turning the key on and off (if I am lucky). Also when I shut it off it will not go back to 0 it stays between 10-15 mph. As far as telling me how fast I am going it might be half of what I am actually doing if it even gets off the 15 mph mark.You have a weak power up cycle. Are you keeping the bike on a battery tender.
The fix is to have the dealership flash your EHC. Right now it sweeps up to 60 and back when you turn the key on. With everything going on to start the bike it doesn't have enough power to power up the speedo.
So the fix is they flash the EHC and then after the motor starts the speedo does a second power up cycle.
Either way you need to keep it on a battery tender and don't use that enrichener when starting and if you have to turn if off immediately.
I'll be going past your area on the 6th or 7th heading to SLC. Maybe we can hook up for a beer in Twin Falls or there abouts!
Do any of yall know if the flash will work for the 08's or do I need a new speedo
Oh meant to add, battery alway on tender adn has 12.7v, original battery from BDM.
