The Baker belt drive is great, not very noisy as in sounding like you have a super charger on your motor. It is easy to install, looks good and it is made specifically for BDM. It is pricey, but well worth it. I had mine chrome plated, to make the cleaning easier and in doing so my warranty was voided. All I had chromed was the outer parts, I will get the motor plate done next time I take it apart.Just looking at the baker belt drive,and wondering-what is the difference between a inclosed pri. and a exposed belt other than looks?:zdrool:
There are others out there that look cool, others on here have Karata Open Primaries that look and sound good. I decided to go with this one. That is just me.
Carlos
aldog, i can answer cause i got one.... the answer is nope, very little or none at all. i just called baker and talked to them about that because i like the whine. they told me if i wanted whine, go buy a junk primary. they said it has to do with the machining. i went with theirs because they give you a 5 yr warranty.
hth, tim
Hey Chacha, you can go to their site and down load or view the instructions. They have picture of each piece by piece.Good look'n set-up Carlos! Do you have a parts drawing for that? I'm looking at out-board support options for the Primo 3"
I don't know if that answer from Baker would be correct :down: I got a Karata and it whines, and Karata has been around alot longer than Baker in the belt drive scene, so junk primaryaldog, i can answer cause i got one.... the answer is nope, very little or none at all. i just called baker and talked to them about that because i like the whine. they told me if i wanted whine, go buy a junk primary. they said it has to do with the machining. i went with theirs because they give you a 5 yr warranty.
hth, tim
Call Baker....they are real easy to talk with and very helpful.Question: The unit that I am looking at is for a 0 degree off set(300 tire).Does anybody know what I have to do to make it work on a 250 tire 1/2 in. off set?
The whine is from the toothed belt engaging the pulley.
As the teeth displace the air in the pulley it creates whine.
Baker uses a different belt and pulley design. With this they have tuned/eliminated the sound.
I don't know if that answer from Baker would be correct :down: I got a Karata and it whines, and Karata has been around alot longer than Baker in the belt drive scene, so junk primary..I once asked Jim from Karata if the whine sound was from my outboard bearing support goin bad, he said it was the belt and pulley making it, I noticed the BDL belt drive on my friends bike and the pulley has wider teeth than my Karata, might be one clue to the whine sound, also my belt was alot tighter/taut than his BDL....maybe Jim can explain it better, or just give him a call :2thumbs:
I love the look of that primary!The Baker belt drive is great, not very noisy as in sounding like you have a super charger on your motor. It is easy to install, looks good and it is made specifically for BDM. It is pricey, but well worth it. I had mine chrome plated, to make the cleaning easier and in doing so my warranty was voided. All I had chromed was the outer parts, I will get the motor plate done next time I take it apart.
Carlos
i agree with you 100%. i thought it may be a easy change to get the whine that's why i called them and that's what i was told.I don't know if that answer from Baker would be correct :down: I got a Karata and it whines, and Karata has been around alot longer than Baker in the belt drive scene, so junk primary..I once asked Jim from Karata if the whine sound was from my outboard bearing support goin bad, he said it was the belt and pulley making it, I noticed the BDL belt drive on my friends bike and the pulley has wider teeth than my Karata, might be one clue to the whine sound, also my belt was alot tighter/taut than his BDL....maybe Jim can explain it better, or just give him a call :2thumbs:
They look and sound cool, and give you something to drag in left turns...
