clutch slipping
joshl
I have a 07 k9 it started of hard to find neutral they adjust my cable still hard to find well now I can hear a noise at sometime at the belt where that jam nut is. Also when accelerating hard the clutch slips normal driving seems ok any advise would be great
surferdude
dry docked
loose nut
If the adjustment thread doesn't work for you then your clutch nut is probably loose ... happened to me twice ... I got a noise from the back too ... I think it's in the disk brake somewhere ... hope you solve your clutch slip :D :up:
AJ SMOOTH
My clutch cable had to be replaced after three times the clutch lever went limp. I attempted to adjust the nut on the cable but came to find out that the mechanic replaced my clutch cable stating that the cable went bad. I have an 06' K-9 with 9,000 miles on it. Suggestion, get it checked out before your cable snaps while riding...take it from me it is not pleasant.
V
This has happend to several bikes including my 08. There are posts on it and even if its not the problem it can eliminate a potential problem in the future:hi:
joshl
Alright I need some more help I did the steps and made things worse I finally got it back where I started first thing is I work on diesel trucks for a living how tight should the rod be before I tighten the jam nut and should I have the bike level and the rear end off the ground
jimizee028
TRUE COLORS COLLISION
i think what they might be saying josh is what i have also experienced twice too...on the left handside you need to take the primary cover off and theres a bolt that holds the clutch basket together and on the motor and usually it is that nut that backs off and gets loose.....
C
chaingunner
Guest
Have plenty of rags ready! Oh, and drain the primary oil first!:D I was doin some pre Sturgis inspections and found my clutch basket nut loose. It seems to be quite common.
jimizee028
well 500 mile service to me tells me bike is new?????????turn it right around and go back to dealer and get them to fix it under warranty
