new custom shit????
Slow Vince
Flag Poles
Actually would really like to see some mounting devices for the BDM chick stick, 2 each.
Rumbling Pride has about the best flags I've seen, and their poles are more than good enough too. But right now, the only way I can think of to mount them is to use Adel clamps, which are kinda cheezy onna 'Dog...
Mario77746
Here is an easy one.....How about a chrome plate to cover that ugly exhaust support bracket on the frame? I don't want to remove it just in case I switch back to my big radius but now it's just an eye sore since I have short pipes. Maybe something with some sort of design on it to bolt to the bracket. Maybe even make it into a inspection sticker plate with a hinged chrome cover???
Hay are you sleeping I don't have all year.
Make me a custom coil cover now:spank:
J/K
:bang: :bang: :bang: :bang:
I would like some easy mount choices with the stock POS coil.
bdmridgeback
Low Down Chop Shop
I was going to do some linkages but the waterjet cut finish wasn't good enough for chrome finish.
Jake
Rick
How about some flame engraved / milled/ whatever rear axel bolt covers? I was going to have mine machined then rechromed. Would rather just but a set. Match them to the BDM flame primary covers.
txchopperguy
I agree a low profile flamed gas cap would be sweet...not as extreme as the 3D spiked ones we have seen. Or maybe a cap in the shape of a maltese cross.
Just a thought for ya.
Chopper Dave
SIICK!!!
I'd be down for one......:up:
Steve....let me know when you do those license plate spikes for the screws....I want 2 sets of 4.......
Cav....did you ever do them license plate screws with the spikes on it?? ....well....I am going to order them stainless ones from motto x...that site that Gas Man gave me....
Hey Cav, I just ran into a problem that gave me an idea to suggest to you for fabrication that would benefit people who have changed out their handle bars and maybe even some who haven't ( I know Raywood also mentioned about how close his speedometer was to his tank). I had switched my chopper bars out on my 05 BDM chopper for a set of ridgeback bars which brought my bars back so I wouldn't need to stretch as much especially on tight turns. Well in addition it also brought them down a bit, enough so that the speedometer and it's bracket are now scraping my tank paint. It was extremely close when I installed them but probably because of a little compression in the handlebar mounting bushings or a little wear in the neck bearings, the paint is being scraped off. When I was looking at the bars and the bracket I noticed that because the handlebars flare out a little as they get closer to the rider just before they make a bend, it would be very possible for the speedometer to nest in that flared out area if a bracket were made that would move the speedometer toward the rider about 1" - 1 1/2 " and upward another 1" bringing it way off the tank. The bracket would also need to angle the speedometer face downward slightly. The bracket could be made to run parallel to and follow the curves of bars and it would look better than the stock bracket especially if it were chromed billet. Does anyone else have a need or desire for a new speedometer bracket?
P.S. I just mounted a set of Kuryakin foot pegs using the clevis brackets you made and they worked out fantastic, thank you
