Hey Cav, I just ran into a problem that gave me an idea to suggest to you for fabrication that would benefit people who have changed out their handle bars and maybe even some who haven't ( I know Raywood also mentioned about how close his speedometer was to his tank). I had switched my chopper bars out on my 05 BDM chopper for a set of ridgeback bars which brought my bars back so I wouldn't need to stretch as much especially on tight turns. Well in addition it also brought them down a bit, enough so that the speedometer and it's bracket are now scraping my tank paint. It was extremely close when I installed them but probably because of a little compression in the handlebar mounting bushings or a little wear in the neck bearings, the paint is being scraped off. When I was looking at the bars and the bracket I noticed that because the handlebars flare out a little as they get closer to the rider just before they make a bend, it would be very possible for the speedometer to nest in that flared out area if a bracket were made that would move the speedometer toward the rider about 1" - 1 1/2 " and upward another 1" bringing it way off the tank. The bracket would also need to angle the speedometer face downward slightly. The bracket could be made to run parallel to and follow the curves of bars and it would look better than the stock bracket especially if it were chromed billet. Does anyone else have a need or desire for a new speedometer bracket?
P.S. I just mounted a set of Kuryakin foot pegs using the clevis brackets you made and they worked out fantastic, thank you
