sick and freakin tired
jimizee028
TRUE COLORS COLLISION
rode till 11 pm last nite ,happy as a pig in shit with my new HID kit from jake,go to get bike out this mornin,turn key,click,click click,voltage is good,battery is charged,4th time this year bike is broke...only have very few amount of days in which i can ride because of having my grand daughter full time and today was a day i could ride after work........i get a red light on my ignition module when i turn key on and a red light and yellow light on the led board....how can it be absolutely fine last nite and this mornin be broke ....this is why i didnt want to build my own and build a turnkey chopper cause i wanted to ride,i didnt want to be the guy no one wanted to ride with for fear ride might end before it begins and would need to turn around and get trailer,,,and now i am that guy after spendin 30 fuckin grand on this piece of shit...i am freakin pissed....and can now relate to the other guys flippin out cause their bikes were all broke,and not being ridden............can someone please help me....as for the reset button i cant even see the button to click cause its mounted in a way that the button is on the bottom and i cant see it to click it...why in the world its mounted this way is beyond me.....what else can i do guys?????????????:angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :angry: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang: :bang:
T.Byrd
my son installed one of those HID lights yesterday and when he rode to my house I went outside to see the light and turn on key...nothing...lights under the seat were all lit up, we had to unplug the battery and I guess it reset it. He said he was taking light out today and going back to the regular light. hope this helps:cheers:
Chopper Dave
SIICK!!!
jimi....sorry to hear your scoot is down....I think they put the reset button facing down so no water or moisture would get in the button....mine is the same way..
Do you have the reset button any more? You should have had it replaced with the fuse.
If all you did was install the HID then pull it and put the stock bulb in and see if it starts up. If it does then your good.
MARV
test the voltage on both lugs of the 40 amp breaker. if they are the same then its not tripped. doesnt sound like it is if your battery charged.
if your battery is at least 12.8 and your getting click at the starter check battery connections and starter ground are tight.
if all good then load test the battery
Nomad2day
Longhair Redneck Geek
I purchased 2 breakers from Napa or through drag specialties that have a internal reset....
Seems I got the info from this forum a while back..
Neil
What is the batt voltage? If low, trying hooking up another battery and try that.
Sounds like its not doing anything. Do you get an ignition light on the ehc come on when you hit run?
I would say you are looking at maybe a bad wire for the right hand control. I don't think the 07's usually have any problems with the hand control board itself. I would shed the tank and check the wires. Could also test the board with a multi meter.
Another possibility, and I would check this first cause its easier, is the solenoid... do a BBChop
http://www.bigdogbiker.com/forums/how/9373-how-fix-click-click-starter.html
Could also test the small red wire going to the starter... pull it off, with bike on, in run, hit start and see if you get 12v on the wire.
On a side note...Gee I guess I'm still crazy crazy..
mobsta
hey jimizee sorry to hear.i have had so many problems with my 04 it drove me nuts.i ended up getting a manual start button mounted on the end of the solenoid that you can push in and engage your starter.this kept me from towing it home a few times and it looks cool to start it that way atleast thats what they advertise.its not a fix but it is a back up
jimizee028
had the starter replaced 1 month ago,the voltage regulator 2 weeks ago,and i am borrowing an ignition module from dealer till mine comes in...tommorrow morning i shall do all that is suggested and return to tell the story,right now takin grand daughter to carnival..............thanks ..and i apolagize for gettin so frantic......i am just gettin to the point i am scared to ride anymore for fear of being stranded
Marco Polo
Newbie DELUXE
I can relate to that. I thought my fear of being stranded caused by all the "funky" starts I've experienced were over once I got myself a Braille battery and saw how much stronger and easier it started. That was until Thursday when I was stranded by the piece of shit due to an apparent starter problem. It's ok though, luckily I only paid $40K and it's already 3 months old so I guess I can't really complain right? :bang: Needless to say, I'm about as pleased as I'm sure you are. It's simply embarassing as hell. :rant:
Old Hippy
It's 4:20 somewhere
Pics??????
jimizee028
ok so i have a horn when i turn the key on and press the buttonalso high and low beam so this rules out my handlebar controls being the issue......correct????,battery is 100% fully charged,however when i press the starter button all lights dim to point they basically aint on,tellin us that tryin to start it is draining everything the bike has.....correct?????????
BBChopper
Supports 2 Disabled Vets
Cables are tight? My money is on the battery or starter at this point!! Need to load test the battery.... Maybe a bad cell or the starter took a dump.
avdhunter
Mine was doing the same thing a while back. I took all the wires off battery, cleaned all the ond connectors real good, cleaned the posts real good then re-installed and snugged up real good. I sprayed some of that anti corrosion spray that U get from autozone on the terminals and posts and (knock on wood) haven't had a problem since! Hope this helps.
jimizee028
did the whole battery and wire clean-up last weekend,and i guess for the mere fact that this is a new starter(which means its probally only rebuilt)i kinda wanted to rule that out...so i will go find me some thicker guage wire and try the battery solenoid test a little later when it cools down,for now me and shorty will be off for a swim on this hot day......
Hook it up to the tender or jump it off you vehicle that isn't running. If it starts then you have a bad battery.
Enjoy your swim with the little one and hope your back up and running soon.
:cheers: :cheers:
Chris is the man!!!! Have half his drive train in my baby!!!:cheers: :2thumbs:
Hey I hate to see folks broke down. Especially the good guys or BBChop. :lol:
Jim... you want me to send the ignition along or wait to see what you find out?? I'll box it up when I get home and there for its ready to go if need be.
