CCRainman
Thanks Jake I'll be in touch.I have sold a ton of them to guys wit cars and trucks. From import cars with aftermarket wheels to guys with slammed duallies with semi wheels on them!!!
They rock when they work and not give you shit. But when they give ya shit they suck balls.I took the monitors off, they are a pain in the a#%
I put 2 oz. in the front and 3 oz. in the back...and took the weight off of the front wheel....that was at 5000 miles...now have 7828 miles on the bike....and tires roll smooth:up: I even have a extra 2 and 3 oz. bag so when its time for new tires...I will be good to go! Dyna Beads are the shit!!:2thumbs:Reason for this...
Dyna Beads shows 1 oz for a 80-120mm tire. The 120 is right on the border of 1 oz and with billet wheels and the over length front ends, the little bit of out of balance gets amplified. I have had about 2-3 people, when I first started selling the Beads, that said they still had a touch of vibration with 1 oz installed.
So all my BDM bike kits come with 2 oz for the front tire. Too much will never hurt a thing with these beads, so a little much is better than not enough!!!:2thumbs:
Some guys are still looking the bikes up and "piecing" together separate kits with 1 oz for the front tire just to save a couple bucks, but they will find out that 1 oz won't do the job!!
I don't know but might have experenced this shake at over 100mph going into a sweeper "onramp" last weekend the front end shook a bit then calmed down while I was feathering the brakes ??? Don't know if the beads had anything to do with this its not a daily thing for me 100mph . It don't really make sense that it would cause this but ?????What do you mean "in the last 3 years"? So old vlv stems they may not go thru? I have experienced this...These have been used in Semi tires for probably 8-10 years!!!
The small 1mm beads just came out that fit through the valve stem in the last 3 years.
2 oz should be more than enough. How much factory lead weight did you take off the wheel?Put 2oz in front and it took most of the bounce out. the bounce is at 50 to55. Added a little more but still a slight bounce. how much is too much to add? 02 pit with a mh90-21/ 33psi.
