yeah hopefully by tomorrow ill buy some mobil 1 20w50, squirt some in, put it in gear and get the pistons moving...after i fire it up im gonna ride around the block and change the engine oil...how many qts should i buy if i plan on running it without the oil filter to pump out all the oil? kn170c oil filter correct? cant find my owners manual
update: put some oil in the cylinders, put it in gear and got the cyclinders moving and then used the starter, changed the plugs and fired right up with a puffy white cloud of smoke...get the bike turned around and there was a puddle of gas...fuel line hose rotted...got it changed with a regular black hose and rode it around the block...sure miss ridin that bitch
change at least engine oil tomorrow or will wait till i figure out what i need for the trans and primary
