DOGESTYLE
DOGESTYLE
I researched and read every post on how to lube heim joints and check for allignment and still a little confused about what to do. I read that the shift linkage needs to be straight from front to back?? I have the BDM extended forward controls and when you look down the side of the bike on the primary side, the front heim joint is future out towards the right than the heim joint connected to the transmission arm. The front heim joint has a spacer on the bolt but its not long enough and neither is the bolt to allign the shift linkage straight. My bike has 6k miles on it and the shifting seems to stick and I have a hell of a time down shifting but going up in gears is fine. Can this allignment be corrected or does this seem to be the norm?
Thanks for the help as always
