rhinoevans
Had the new wheel mounted and I put it on this morning. Saw that the previous alignment was not correct so I corrected it for proper belt deflection. When I spin the wheel forward, all is good. When I spin the wheel backwards, the belt has a slight climb on the right side at the top of the wheel sprocket that the belt "rides in" on the rear wheel. Also, I need a picture of the rear wheel that shows the axle and spacers. I am guessing they are all correct since the rear brake caliper when on correctly. Although 2 of the spacers, and I think they are the ones on both outer extremes had a little lip on them and I was not sure which way they went back. I know I need a manual, and am puchasing one from a forum member but have not completed the deal. Thanks for any help
Can the belt, forward of the rear wheel on the transmission sprocket, be mover over a bit. Mine would need to go the the left just a hair to solve the belt/sprocket issue?
2002 Pitbull 250- rear tire
