FORK BRACE ?
RADAMS445
RADICAL
Hey gang,has anybody put a fork brace on a 06 mastiff? I was wondering if somebody might start me out with a size (mm)and a manufacturer.Thanks.:confused:
We know that all the Prostreets didn't have them but I would think all the lower legs are about the same to same money at the factory.
Look on the inside of your lower legs just below the top caps and see if there are a couple of set screws? If so then those are where the stand-offs go that the brace would fit too. Sorta like the left side where the brake is, it's just bolted to the lower leg!
Worth a check anyway.
RADAMS445
RADICAL
I'm assuming that because of the fender brace it would have to go directly on the forks(lower leg).Does this sound correct?
06 mastiffs didn't come with fork braces.He will need aftermarket info.
That's what I'm saying... the fork braces like the one Martin Brothers sells will bolt right up where the bdm fender struts bolt to the forks.
It probably would on your bike. On the looooonnnnnggg front ends on some customs they have the clamp on ones for the tubes but your bike's lower legs probably when retracted wouldn't be worth having one (on the tubes that is).
Are you wanting it just for show?
RADAMS445
RADICAL
No,I wanted to just tighten the feel. I,m not use to the front end but maybe this is nornal.My last bike was a sporty and it made a huge difference to me.
here's what I'm talking about..
Alhall's bike and his badass front end
With the front fender and its struts
With a martin brother fork brace. It bolts up where the fender struts USE to bolt to. This is a HD standard.
Could it be that your neck bearing are just a bit loose. I've never experienced any loose feeling in my Mastiff. Different animal though on the Chopper!
how about one like this
That's the tube clamp I was speaking of. But on you guys prostreets you would have to figure out where your highest compression is on the tubes then you may find out the clamp would be right under your lower triple tree!
Unless you could manufactur one to go around the lower tubes if you have room above the fender.
:eek:
RADAMS445
RADICAL
Chris those are inverted forks right,mine stay stationary at the bottom-and I diffenitly need to keep the front fender on! That bike is the definition of BADASS!To keep The fender I thought it would go over the fender tight and attach to the legs.Although Raywood might be right about its worth
Those are... but the concept is the same
