Troubleshooting speedo issue, need a little help
BrianLo
With a relay it doesn't matter. What matters is that you wire it to the correct contacts. :up:
Wow, must have been drunk when I posted that... based on what was previously posted, here's a diagram
Makes things a little clearer... So if you wire it as Night Train suggested, it will only interrupt speedo power when starter circuit is powered.
DRBarnhart
Insert title here...
All 5 pins are normally closed, or will I need to ask for one specifically?
Here's the part number of a Harley starter relay (it fits all the older bikes):
31506-79-C
It has the contacts you need, it's about 1" square, and has a small bracket build in for you to mount it with. :up:
And I believe the part number of the connector body that goes on it is:
72046-79 (and uses 1/4" female spade connectors)
If you don't want to mess with the whole connector the 1/4" spade connectors would work alone but a fully assembled connector would look more professional! :)
Both of these could have been superceded by now but at least it should give the Harley parts guy a starting point... :D
Dennis
Moespeeds
Wired in the relay, I'll see how well it works tomorrow. Thanks again for all the help guys!
