Sorry for the belated post but the hole is to the rear, however there is no wobble. The tank is solid. I remember looking up the backbone prior to engaging the front clamp and the tank was tight against the rear mount. The rubber on the front mount is against the front of the pocket in the tank on the clutch side. I'm going to have it sent back to BD next winter to repaint again anyway so I will keep this in mind when remounting. ThanksJust curious - look under your tank and at the mount - there should be two bolts and an empty hole - where is that "empty hole" to the front or rear of the bike? If its in front then all is good and possibly a new tank. If it is in the rear it's not mounted correctly - hence the gap (and you should feel a slight wobble) - Again, Just curious let us know....TKS
