JoshT
Alright fellas... im reaching out for some help here!! Over this winter I have installed a new dual coil set up, and I believe that I have it set up right from what a few guys here have told me. But as my luck my have it I have NO SPARK!!!.. On my bike (04 Ridge) I have the Thunder Heart Ingition and had the factory Dyna single coil. I took off the single and put 2 Dyna 3ohm coils. I followed the wire harrness and from the backbone of the frame there is One set of wires that are for the Key switch (that has a clip on it) and 2 more wires. One Red, and One Yellow. Now according to advice that I was given, I should have run the red to the front coil and mount on the inside stud. Then the yellow wire to the outside stud and then jump them to the other coil. With that done I have no spark to the plugs. I have checked the studs on the coils and both the red and the yellow are getting power when I try to start the bike. So what do you think it may be???? Plug wires are good and plugs are as well. :bang:
