HOW DO YOU CHANGE A FINAL DRIVE BELT ???
chihuasbigdog
LATINAMERICAN AFFAIRS
You all, my final drive belt is broken, I ve just bought the one of Gates developed by S&S and 'em....
04 ridgeback.
im willing to change it myself, so advices where and how to start would be highly appreciated!!!
chihuasbigdog
Yeah, you got it easier with the Rigid! :D
THANKS BROS, AS A MATTER OF FACT AND KNOWING NO SHIT ABOUT MECHANIC ISSUES (JUST BASICS) :roll: :roll: :roll: , I THOUGHT IT WAS GOING TO BE EASY WITH THE RIGIDS....
ANY MORE ADVICES SHALL BE WELCOME !!!!
Pullin the primary the first time is probably intimidating but once you get it off you will see it's not complicated at all.
I would take the opportunity to verify tranny alignment and ensure everything is shimed accordingly. This will ensure the belt tracks true.
Have fun,
Ray
chihuasbigdog
Left side drive ridgeback would be easy. Just remove outer primary, and clutch basket,compensator sprocket assembly with primary chain and then the inner primary to expose transmission sprocket. Finally remove rear wheel to slip on belt and reassemble. Follow this thread and it will help for the disassembly portion.
http://www.bigdogbiker.com/forums/how/180-how-convert-chain-belt-drive.html
Dude !!! you're the man!!! i ve just take a look to your thread, so easy even for a beginner like me :whoop: :whoop: to do it !!!
thanks a lot!!!!
chihuasbigdog
TORQUE VALUES FOR COMPENSATOR ADN CLUTCH HUB NUTS
hi, im putting a new belt drive, anyone who knows the torque values for compensator nut and the rear clutch hub nut????
04 ridgeback.
thanks a lot.
04 ridgeback.
thanks a lot.
Front compensator nut according to the manual 165-175 ft. pounds and red loctite. Clutch hub left hand thread and 70- 80 ft. pounds
