A few days ago I posted this (second paragraph below), I found the problem. The wire that connects to the solenoid on top of the starter was cracked and bare. It was making contact on a bunch of wires. You better check yours. I looked at the new dogs at the dealer yesterday and they were cracked also. Stand on the right side and look between the battery cover and the belt drive. If it is cracked you will see copper wire showing through. I pulled the cracked rubber off and put two layers of shrink tube on, reinstalled the battery and walla bike started right up.
I have a 07 K9. I have it in storage for the winter in my basement. I did not have it on the trickle charger when I noticed the right turn signal reminder light on the speedo was on and the speedo needle stuck straight up. I turned on the key and nothing changed. I took off the seat and all of the lights on top of the computer were on and would not turn off unless I unhooked the battery. Once again nothing changed with the key on or off. I pulled the battery and it checked out good and fully charged. I hooked the battery back up and same thing.
