How to
TVDR
06 Ridgeback
Hey guys looking to find instructions on installing the passerger pegs and bracket. It looks pretty simple. Wondering if there are any how to's on the install..:cheers:
V
After you install the wishbone (bracket) for the pegs make sure you have enough clearance to remove your oil fill plug. On my 05 I had to shim down the rear of the oil tank about 3/32". I did this per instructions from Big Dog tech dept. :hi:
Cool Stuff thanks guys should i go with the pillo pad or the 2 up seat?:cheers:
If you search "seats" you will find this quetion has been asked many times. I have both and as for the front seat the single is better than the 2up.
For the rear the 2up is WAY more comfortable for your passenger than the stick-on. The stick-on slope down causing your passenger to constantly slide forward when you slow, shift or brake. The 2up is more cupped to hold your passenger in place better.
We recently did a group buy for the 2up prior to Sturgis this year for a great deal.
erldawg
Ray is that two up more or less a stick on like all the other seats? I've been considering one of them for the lady of my choice instead of the pillow.
CURDOG
Erl, the two-up seat has suction cups at the rear of the seat just like the single seat does.
