Thunder Heart Q?
C
chaingunner
Guest
Ok, so my chick calls up to order the Thunder-heart ignition for me for x-mas. The chick on the other end of the phone says I don't need the ignition module as a kit (PN# ASM5012) ???? So I have no idea that she was doing this, well she didn't want to get the wrong deal, so she had to ask me, hmmmm, I have no freakin clue......:confused:
Stock 07 K9 117", 2 into 1 V&H, stock air cleaner with K&N filter.
I will be installing a .600 S&S cam and a XXX carb, but this will be later.
Question is do I need the PN# ASM5012 or PN# ASM5075?
Thunder Heart Electronic Products
Oh and any one know if Nelson from WB sells this? Or some one on the forum...
Thanks for the help in advance. :up:
bdmridgeback
Low Down Chop Shop
You need the 5012 for sure, the 5075 is Harley direct plug in to HD harness, will not work on our bikes.
Thunder-Heart only sells our module in the ASM-5012 kit and no other way, I tried!
RRRUFF
My friend jerr-06K9 and I just put one on his bike. His kit came with the ignition module, coil, plug wires, & the software to load on a computer to program the ignition module. You don't really need the coil or the plug wires but you will probably need the software to set up the ignition for your bike. So you will probably need the kit PN# ASM5012 and there maybe a different PN# now. PM jerr-06k9 for the PN# he got.
bdmridgeback
Low Down Chop Shop
They don't sell just the module and software, I even called Thunder-Heart to try and buy it that way and they said complete kit only.
Oh well! Some day I may need that coil as well.
C
chaingunner
Guest
Sweet! I don't know why she told her that then, but she could have been misunderstanding...
Thanks guys! Now I can't wait!
WB Cycles
Chain ... I can get Thunder Heart for you ... as well as the stock BDM of course. Shoot me a PM if you're still in the market and we'll see what I can get.
C
chaingunner
Guest
:2thumbs:
Will do, thanks Nelson!
Shane
T Mack
SUCKER FREE
so i need to change this a.s.a.p.?????
then i need to get rid of the EHC in my bike....??
Im gonna do these mods a.s.a.p. with a little help from you guys....
me being a electrician by trade... i should be able to tackle these mods..... I HOPE!!!!!
bdmridgeback
Low Down Chop Shop
I can see it now... Romex pulled through conduit, with a 110 electrical switch for the ignition cut off and a dimmer on the headlight switch.
:roll: :roll: :roll: :roll: :roll: :roll: :roll:
Just let us know, we'll help you out, just post up what you THINK you need before you run to Home Depot to get it! :D
You might as well swap out the voltage regulator and stator as well. Get rid of all the BDM stuff!
T Mack
SUCKER FREE
Silly Fucker!!!!!!!!!!
Now that shit was funny bdmridgeback... :roll: :roll: :roll: :roll:
P.S. just added the voltage regulator and stator to the list...
bigdave
Ive got an 98 k9 where is this located on the bike? All I can find is an S&S VFI and the EHC under the seat
Yea Brew, we all have fat fingers, give the new guy a break and answer his question.:)
