Yeah, I was very pleased with the results.
One thing I forgot to mention in my dyno chart post is that I did remove the restrictor plates. Funny thing is that the dyno guy didn't think that removing those and staying with a Super 'E' carb, even though it's the upgraded version from Triple X, would do much good as I still had the stock intake manifold. Maybe he's just not that familiar with the carb and restrictors. Regardless, I think he ended being as pleased as I!
Now I just have to get the bracket for the new pipes a bit more dialed in. I used the one supplied with the pipes, which has 2 holes that don't line up with the tranny bolts, and a hunk of metal bolted up to that to get it to reach the pipe's bracket holes.
By the way Raywood, does your bike also have two holes located towards the rear where mine had an exhaust bracket? You can see them in the picture below located just behind the bottom pipe. May need to figure out a way to cover them up.
By the way, my bike will be turning 49,000 miles this weekend!
