Does anyone recognize this?
stlmikie
I wish I had more money.
I found this under the bike the other day. I'm not sure that it is off the bike. I looked and couldn't find a spot for it but still would like to know if it is the bikes or not. Thanks for the help.
BigDognSoCal
from the looks of the head you have had a wrench on it a time or two...its from your license plate bracket...
stlmikie
I thought you were right for a minute. I looked and it is simular to those no doubt. This one is a size or two bigger than those.
BigDognSoCal
Well look around, its from your bike...tank mount? naw to dirty... maybe from inside the battery box, some counter sunk type, from some bracket thingy...thats all I got...
Big Ron
Time for a new one I'll tell you that. Be glad its off because it won't go on tight with rounded allen like that:cheers:
BBChopper
Supports 2 Disabled Vets
Gas
Need the thread size and length.
Maybe Gas can rip his bike apart and match it up for ya??:eek:
But he’s gona insists on that thread size and length first!!:2thumbs:
EJ
Looks like a derby cover bolt. Right side boottom of the motor. One of mine fell out.:confused: Good luck.
bdmridgeback
Low Down Chop Shop
If is is a size bigger than the license plate trim ring bolts, then it is the bolt that holds the plate to the mount.
If you turned your plate vertical a while ago, then that is it. There are four bolts holding it on from the factory and when you rotate it up vertical, only three hold it on. That is your extra left over screw!!!
Sean_BDMATL
Have you found what it is yet? If not, if you can get me thread pitch and size, plus length. I can search big dogs parts online to tell you what it could be. Just pm me.
