Yes Dave it does it every time. There is no oil to be changed in the primary. It’s an open primary. From what I can see the teeth on the exposed gear look fine. I would have to pull the starter to see the teeth on the bendix. Sounds like a week end and a wallet draining project to me.I agree with WAYKOOL the starter drive,Bendix gear teeth and clutch ring gear aren't meshing correctly, it more than likely has a worn spot on the clutch ring gear, and when you roll the bike in gear either forward or backward its turning the ring gear away from the worn spot enough for the Bendix to mesh together,and once the engine starts spinning it spins past the worn spot, I have seen this same exact thing on several engines, I cant see it doing this every time though, does it do this every time or most of the time? if it was just a worn Bendix rolling the bike in gear wouldn't make any difference,if it was mine I would try starting the bike and if it grinds pull the primary and look at teeth, its time for a primary oil change anyway with all that grinding.. good luck..Dave.
is sorta worn but the wife still likes to ride it from time to time. Hahahhahha....
a word to the wise. stay away from interstate batteries. they are not what they are advertised to be. stated as 320cca. but actually 270cca and very weak. the last one i bought (just got my money back on it) after being on the initial charge before i put it in the bike was only 12.85 volts and the beast needs 12.8 to crank. not very much in reserve.
