rcdude69
I've searched the forums looking for a solution but didn't have any luck. I was working on the indicator (idiot) lights on my 2002 Bulldog. After I got done I tried to start the bike and it wouldn't start. All lights work, engine turns over fine, but I don't have any spark at the plugs. When I first turn the ignition on the red light on the thunder heart ignition module comes on and then goes off. It does flash on and off while the bike is turning over. There is power to the lower wiring terminal on the coil and the ohm reading between the two terminals is around 3. The same thing happened yesterday, the bike would turn over but not start. I had a couple things to do in the house so I took care of those and went back out and tried to start the bike and it started. My first thought was that I had flooded it but apparently not. Does anybody have any ideas? Any help would be appreciated.
