Nomad2day
Longhair Redneck Geek
I know the belt is 1 1/8th inch wide. What is the pitch and number of teeth I need for a 2007 Bulldog? Where to order from? The manual appears to be worthless here, only states 1 1/8th.
Mine has a good nick in it and needs replacing...
Thanks in advance for any info
Neil
Page 64 of 2008 Performance Guide by S&S Cycle
1958-2008 50th ann iversary s&s®/gates® high strength final drive belts how many final drive belts have s&s engines broken yes a lot of power can break things so what s the solution the solution that we are offering is stronger belts s&s has teamed up with the gates® corporation a leading manufacturer of power transmission belts to offer a series of secondary drive belts for many popular v-twin models these belts feature gates super strong x3n carbon cord material which is significantly stronger than the aramid material used in many oem final drive belts s&s final drive belts by gates are available with 14mm pitch in 11/2 and 11/8 widths see the chart below and match the width and number of teeth required for your vehicle you can find this information in the vehicle service manual 106-0361 secondary drive belts 14mm pitch teeth 125 126 127 128 130 132 133 135 136 139 11/8 wide 106-0357 n/a n/a 106-0358 106-0359 106-0360 106-0361 106-0362 n/a 106-0363 msrp $164.95 * * $164.95 $164.95 $164.95 $174.95 $174.95 * $174.95 11/2 wide n/a 106-0348 106-0349 106-0350 106-0351 106-0352 106-0353 106-0354 106-0355 106-0356 msrp * $174.95 $174.95 $174.95 $174.95 $174.95 $177.95 $179.95 $179.95 $184.95 email us at sscust@sscycle.com 64
Neil
