JerryC
My throttle side controls are loose on the handlebar. While holding the grip, I could lift up and the whole control would move about an 1/8th of an inch. The allen screws were tight. I just took the brake apparatus off, and see that the throttle assembly has a shaft that inserts into the handlebar. That is what is moving up and down - the shaft that goes into the handlebar. This did not happen until I broke the brake lever, and had Rockstar replace it. The small movement doesn't seem dangerous, but it also isn't right, and I am curious as to why it is moving and how to tighten it up. The allen screws on the brake assembly just tighten the brake up onto the handlebar, but do not eliminate this "lift" caused by the shaft going into the handlebar that moves.
Does anyone know how to tighten this up so that the throttle/brake assembly does not move on the handlebar?
